Home/
Author Zing Zai Loo
Summary3 min read
    • Why Smooth Flow?
    • The setup
    • Conclusion
    In Oct 2021, Salesforce announced that Workflow Rules and Process Builder would be retired in the near future. Building flows using Flow Builder will be the way forward where it would be a one-stop shop for low-code automation.
    Why Smooth Flow?
    DocuSign Envelope Status component
    Smooth Flow updates the object’s Chatter post whenever an envelope status changes. I have saved Smooth Flow for last in my blog series as it is so smooth, it applies to envelopes sent in Part 1 and Part 2.
    Example
    DocuSign envelope status in Chatter update
    The setup
    Setting up Smooth Flow
    Selecting a new Record-Triggered Flow
    Configuring the trigger
    Step 2: Get records
    Adding the first Get Record data element
    Step 3: Create new resource
    Creating a new Text Template resource
    Step 4: Update Chatter
    Creating a new action to update Chatter
    Author Zing Zai Loo
      Innovating in the open: Docusign releases 1FE micro-frontend framework
      Author Mark Peterson
      Mark Peterson
